Shop Discount Sea-Doo Parts
No Power
DMB2020
Messages
4
Likes
0
Water Crafts
Seadoo 1996 GSX
#1
I have a ‘96 GSX and I went to go start it up put a brand new battery in and I went to start it and got nothing. When I put the key on I am getting no beep or light any idea what could cause this?
JJinSC
Messages
1,254
Likes
31
Location
SC
Water Crafts
1997 Sea-doo XP
#2
Do the gauges come alive when you put the key on? If so, you could have more thank one issue. The beepers go bad in these. If gauges are working when key is on, I would troubleshoot/replace beeper and test starter solenoid. All this assuming that brand new battery is good and fully charged.
Ckrawiec
Messages
590
Likes
92
Location
Rochester, NY
Water Crafts
1996 GTX, 2017 Spark 2up
2018 GTS
2006 Bayliner 185BR
2019 Misty Harbor 22' pontoon
#3
1) please verify that battery cables are connected to the proper battery posts...yes people have inadvertantly switched them.
2) NO KEY...press SS button...does the ski wake up? message on the guage? If no, then you don't have battery power to the MPEM. Trace RED battery cable to electric box, open box, check 15 amp fuse....if bad - replace, if good keep tracing wire (probably Red/purple) to mpem....check fuses on the mpem (should have 5 and 15 amp fuses there)...test all wiring for continuity as well.
3) SS switch could also be bad, beeper is bad, DESS post could be bad
4) report back with findings and we will continue with suggestions....
Users who viewed this discussion (Total:16)
SPONSORED LINKS
Latest posts
Usergroup
