No fuel coming out
Be sure the fuel lines are connected correctly and apply the choke to pull the dry fuel lines full of fuel. It should fire up after a few seconds. Remember to not just hold the starter too long as it will over heat. Just hit it for a few seconds at a time to keep it from over heating.
Karl
Karl
Finally got it to work. I even took the line out and try to blow gas through. I took the filter cover off and spray some engine starter and it got the engine to finally start for good
Just curious, I did try the choke before pressing the start button. Also tried pulling the choke while the start button was pressed on. Is this right procedure?
Btw, I always took the carb out and cleaned it.
Tony
Glad you got it running...try not to use starting fluid on the engine as it has no lubrication properties in it, and could cause damage.
Karl
