PLEASE HELP So i have a 98 challenger 1800 w/ twin 787 and can not get the starboard motor to crank over. We were out tubing for the day and had no problems all day. Last ride before we were going in i went to start the motor and got nothing but a click. got the port side motor to turn over fine no problems. Got home and figured it was a starter problem so i removed it and hooked up a battery jumper pack to it and it spun over fine. lots of power no problem. so next i figured OK starter solenoid. got the updated on from seadoo and re-installed everything and have the same condition. all i hear is a click but the motor doesn't crank over or try to. all the wiring looks good the positive cable gets hot when you crank as well as the starter. i even tried wiggling the wires to see if i could get anything different like if it was a loose connection but same thing just a click. it sounds like the starter drive is kicking out but not sure if the motor is frozen or could the ring gear have missing teeth i'm kind of lost at what to try or do next. thanks for any input. just installed a new neg cable from the starter to the bat and same condition.
