Page Time: 0.0038s
Memory: 1.4183 MB (Peak: 1.6234 MB)
Queries (3, time: 0.0000s, 0.0%)
    Included Files (99, XenForo Classes: 35)
    1. index.php
    2. src/XF.php
    3. src/vendor/autoload.php
    34. src/XF/Http/Request.php
    35. src/XF/InputFilterer.php
    36. src/XF/Pub/App.php
    37. src/XF/App.php
    38. src/XF/Container.php
    39. src/config.php
    40. src/config.controls.php
    41. src/config.override.php
    42. src/XF/DataRegistry.php
    45. src/XF/CacheFactory.php
    54. src/XF/Extension.php
    55. src/XF/AddOn/Manager.php
    65. src/XF/Http/Response.php
    66. src/XF/Util/File.php
    69. src/XF/PageCache.php
    70. src/XF/Mvc/Entity/Manager.php
    71. src/XF/Mvc/Entity/ValueFormatter.php
    72. src/XF/Repository/SessionActivity.php
    73. src/XF/Mvc/Entity/Repository.php
    74. src/XF/Repository/User.php
    75. src/XF/Entity/User.php
    76. src/XF/Mvc/Entity/Entity.php
    77. src/XF/Entity/LinkableInterface.php
    78. src/addons/XFMG/XF/Entity/User.php
    79. src/addons/XFRM/XF/Entity/User.php
    80. src/XF/Mvc/Entity/Structure.php
    81. src/addons/Andy/ApprovalQueueLocation/XF/Entity/Listener.php
    82. src/addons/Andy/DisablePushNotificationsPrompt/XF/Entity/Listener.php
    83. src/addons/Andy/MostReactions/XF/Entity/Listener.php
    84. src/addons/Andy/Trader/XF/Entity/Listener.php
    85. src/addons/Andy/WeeklyNewsletter/XF/Entity/Listener.php
    86. src/XF/Entity/UserAuth.php
    87. src/XF/Entity/UserOption.php
    88. src/XF/Entity/UserProfile.php
    89. src/XF/Entity/UserPrivacy.php
    90. src/XF/Data/Robot.php
    91. src/XF/Util/Ip.php
    92. src/XF/Db/Mysqli/Statement.php
    93. src/XF/Db/AbstractStatement.php
    94. src/addons/XFCloud/_vendor/jaybizzle/crawler-detect/src/CrawlerDetect.php
    95. src/addons/XFCloud/_vendor/jaybizzle/crawler-detect/src/Fixtures/Crawlers.php
    96. src/addons/XFCloud/_vendor/jaybizzle/crawler-detect/src/Fixtures/AbstractProvider.php
    97. src/addons/XFCloud/_vendor/jaybizzle/crawler-detect/src/Fixtures/Exclusions.php
    98. src/addons/XFCloud/_vendor/jaybizzle/crawler-detect/src/Fixtures/Headers.php
    99. src/XF/Debugger.php
    DB Connection Stats
    bytes_sent1091
    bytes_received872
    packets_sent24
    packets_received33
    protocol_overhead_in132
    protocol_overhead_out96
    bytes_received_ok_packet0
    bytes_received_eof_packet0
    bytes_received_rset_header_packet45
    bytes_received_rset_row_packet90
    bytes_received_prepare_response_packet566
    bytes_received_change_user_packet14
    packets_sent_command11
    packets_received_ok0
    packets_received_eof0
    packets_received_rset_header5
    packets_received_rset_row5
    packets_received_prepare_response16
    packets_received_change_user2
    result_set_queries1
    non_result_set_queries4
    no_index_used0
    bad_index_used0
    slow_queries0
    buffered_sets0
    unbuffered_sets0
    ps_buffered_sets1
    ps_unbuffered_sets0
    flushed_normal_sets0
    flushed_ps_sets0
    ps_prepared_never_executed0
    ps_prepared_once_executed3
    rows_fetched_from_server_ps1
    rows_buffered_from_client_ps1
    rows_affected_normal0
    rows_affected_ps0
    rows_skipped_normal0
    rows_skipped_ps0
    copy_on_write_saved0
    copy_on_write_performed0
    command_buffer_too_small0
    connect_success1
    connect_failure0
    connection_reused0
    reconnect0
    pconnect_success1
    active_connections1
    explicit_close0
    implicit_close0
    disconnect_close0
    in_middle_of_command_close0
    explicit_free_result0
    implicit_free_result1
    explicit_stmt_close0
    implicit_stmt_close0
    mem_emalloc_count0
    mem_emalloc_amount0
    mem_ecalloc_count0
    mem_ecalloc_amount0
    mem_erealloc_count0
    mem_erealloc_amount0
    mem_efree_count0
    mem_efree_amount0
    mem_malloc_count0
    mem_malloc_amount0
    mem_calloc_count0
    mem_calloc_amount0
    mem_realloc_count0
    mem_realloc_amount0
    mem_free_count0
    mem_free_amount0
    mem_estrndup_count0
    mem_strndup_count0
    mem_estrdup_count0
    mem_strdup_count0
    mem_edupl_count0
    mem_dupl_count0
    proto_text_fetched_null0
    proto_text_fetched_bit0
    proto_text_fetched_tinyint0
    proto_text_fetched_short0
    proto_text_fetched_int240
    proto_text_fetched_int0
    proto_text_fetched_bigint0
    proto_text_fetched_decimal0
    proto_text_fetched_float0
    proto_text_fetched_double0
    proto_text_fetched_date0
    proto_text_fetched_year0
    proto_text_fetched_time0
    proto_text_fetched_datetime0
    proto_text_fetched_timestamp0
    proto_text_fetched_string0
    proto_text_fetched_blob0
    proto_text_fetched_enum0
    proto_text_fetched_set0
    proto_text_fetched_geometry0
    proto_text_fetched_other0
    proto_binary_fetched_null0
    proto_binary_fetched_bit0
    proto_binary_fetched_tinyint0
    proto_binary_fetched_short0
    proto_binary_fetched_int240
    proto_binary_fetched_int0
    proto_binary_fetched_bigint1
    proto_binary_fetched_decimal0
    proto_binary_fetched_float0
    proto_binary_fetched_double0
    proto_binary_fetched_date0
    proto_binary_fetched_year0
    proto_binary_fetched_time0
    proto_binary_fetched_string0
    proto_binary_fetched_json0
    proto_binary_fetched_blob0
    proto_binary_fetched_enum0
    proto_binary_fetched_set0
    proto_binary_fetched_other0
    init_command_executed_count0
    init_command_failed_count0
    com_quit0
    com_init_db0
    com_query2
    com_field_list0
    com_create_db0
    com_drop_db0
    com_refresh0
    com_shutdown0
    com_statistics0
    com_process_info0
    com_connect0
    com_process_kill0
    com_debug0
    com_ping0
    com_time0
    com_delayed_insert0
    com_change_user0
    com_binlog_dump0
    com_table_dump0
    com_connect_out0
    com_register_slave0
    com_stmt_prepare3
    com_stmt_execute3
    com_stmt_send_long_data0
    com_stmt_close3
    com_stmt_reset0
    com_stmt_set_option0
    com_stmt_fetch0
    com_deamon0
    bytes_received_real_data_ps4
