drjrmorgan
Hello. thanks for the great resource for seedoo info:
I have a new 96 Speedster with the twin 718 cc Rotax engines, only 5 hours on engines and boat. running urine yellow oil in the injectors apparently very heavy mix by the smoke and oillyness of exhaust. Prior owner says it is official seadoo oil ?? Would I be better to switch to QS synthetic blend (not TCW3) ? I have read many of these oil threads and see that I should probably run the QS Blend or the QS full synthetic PWC oil.
2: will this boat plane on only one engine ??
would it cruise on one engine if I started it on both and then killed one of the engines wnce on plane ?? ( I am going to Lake Powell and want to maximise my range)
3 the prior owner put custom marine air filters (look like K&N cone type) on the 4 carbueraters. Is this safe or desirable ??
4. I saw that there are two approved spark plugs (the NGK 8 and NGK 7) plugs, which should I use when ?? should I have both for if one fouls ??
5 I live on the Colo river and there is lots of "eel grass which cavitates the impellars. Is there any way to avoid this or lessen this ?? Will the after market impellars do any better agains fouling with grass ??
6: where should I tap into the power to add an accessory "cigarette lighter outlet "
Thanks for any expert advise you might have
Rick
Rick
