mashenden
I recently bought a galv trailer that came with a '95 SP. Thanks to this forum and on-line manuals, I have evaluated what I have as follows:
So far, so good. My concern is that I found gouges in the rotary valve cover, the valve, as well as to a lesser extent, on the block side of the valve. I have seen some posts that say it is not that terrible, but it sure looks like it is bad. Any thoughts on whether I should just 1) clean the carb and reassemble to see if it runs vs being overly hard to start (keeping in mind I am not trying to restore it to perfect or anything) or 2) replace the valve and possibly the cover now while I am at it? If the latter, any idea on costs for the valve and cover?
- SP - low end PWC (which is fine for me and my kids at this point). I realize it is on the lowest end on value. Someone noted it as the fat chick of jet skis. Fun to ride until your buddies show up and see you with it .
- Clean with what appears to be light use.
- Old tank that I can get replaced for free from the "recall". Gray gas lines that I can replace for about $30.
- Broke open the carb and it looks in great shape, although the filter was near clogged (gray lines are likely the cause on this).
- Tested ignition and spark looks strong on both.
- Needs a battery. Can get AGM for about $80.
