I am about to purchase a 98 gsx limited and a 97 xp that have been sitting since 2002. I am a quick learner with engines but because I have no prior experience with these machines I wanted to get some input from the pros.
Because they have been sitting for so long, I was going to rebuild the carbs, change air filter and spark plugs and clean old fuel like I would any engine sitting for this long.
I was curious if there is anything else I should check even after they are running to try and avoid further damage to expensive parts. Also, neither have a key, from my understanding they can run without the key but remain at idle...??? If this is the case, I can work on getting them running before purchasing a key...??? Are there any bearings and such that are easily accessable to re-grease?
