JJinSC
Well, Everything has been running fine this year. Just to review. I had whole engine rebuild last year. Carbs rebuilt with OEM kits. New oil pump and lines. I rebuilt the RAVES (Completely). New baffle. Fuel lines replaced 3 years ago. Had a flooding problem last year and replaced pressure relief valve on fuel vent. Flooding problem solved. Now the new problem this year is I can crank it up ride all day with no problem. Cut it off and let it cool down and crank it up and ride as long as I want again with not problems. However, If I take a ride and then cut it off for over five minutes, it does not want to crank well. It will fire each time and then cut right off. I have to choke and pump throttle to get it to clear out and it's not easy. Once clear out, it will run fine again. Twice today I had this problem and after I got it cleared out and pulled it back up on the dock and blipped the throttle to clear the water, I had a runaway (twice). Any ideas?
