I bought a 97 Speedster last summer. Long story short, Starboard side motor runs great, Port side motor misfires back into the carb. Carbs were professionally cleaned, new fuel, plugs, etc, I even switched the carb and ignition coil from the Starboard side to the Port side and it still misfires. The magnito and rotary valve are aligned as they should be. I checked the timing and it seems as though the PTO mark is 1/4 turn off!!!, (the system fires when the piston is half way back down the jug), not at TDC or anywhere close. I can't adjust the armature plate that far..... What would be causing this incredible timing misalignment? Would a bad magnito be the issue? I'm out of ideas, any help is appreciated.
Thanks
Greg
Thanks
Greg
