Jakemonson810
Hey, I bought a 1995 xp. It’s got the 717 motor in it, finally got it running. But there is a lot of oil in the cylinders. It has been sitting for couple years. Was reading up that crank seals could probably be bad. Causing the oil to be in cylinders. I don’t know if it’s necessary that but looking to see what else it could be. Also read that I could eliminate the oil injection instead of tearing motor apart and just premix the gas. Was just curious on your thoughts. Would it hurt to do eliminate it for a little bit to test the machine or is it bad for the engine ? New to these machines looking for advice
Thanks
Thanks
