Scubadave16
Hello
I have a 1996 Sea Doo Challenger which was running fine until yesterday.
When I accellerate, I only get about 5500 Rpm out of the motor and it just bogs down. I had my buddy sit way in front and i managed to get it on plane and then the rpm went up to maybe 6300. Max speed about 30. last week it was much faster and ran about 6800 rpm.
I also notice a slightly different sound in the engine, maybe a bit more throaty and rumbly for lack of a better description.
so what changed? I filled up the gas tank. the gas came from the marina and I always fuel up there.
so what have I done?
I checked the plugs- OK, not fouled.
I checked the fuel filter- clean
a buddy suggested I check the RAI? valves on top of the cylinders. they move freely.
plug wires are connected and clean.
another buddy says I should change spark plugs, but i doubt that is the problem.
In addition, I notice that the gasket around my exhaust pipe through the hull is cut and water pours in when 2 big guys are leaning over the engine compartment. this seems unrelated, but thought I would mention it.
Another oddity, after testing it i heard a trickling sound coming from the muffler area. not sure what that was about. no water was leaking into the boat so it must be inside the muffler.
I am open to suggestions as to what might be going wrong and what I should try next.
Thanks a lot in advance for any help.
Dave
Dave
