MY seadoo 4tec 4 stroke parts ad: starting with 2005 RXP lots of freshwater parts
99spxxx
2005 RXP PART OUT: low hour freshwater.
LCD is mint inside and out...
Pump is a little chipped up on veins but very usable and cheap/// I also have three brand new 4tec alum pump with wear rings i stock
ECU is in working order no key also have a 155 non super charged gtx ecu.
I also have 6 mpem for most if not all 2003-2008 4tec
Pm me or call with questions or your part needs.
Thanks
Jess
813 363 9074
jesscairns@yahoo.com is my paypal
278002043 program module mpem 278002035 Center LCD Gauge 278001993 Speed Sensor Impeller 276000283 267000216
278001605 vts module 274001049 Exhaust Pipe 274001366 Résonateur 274001095 muffler 270600056 fuel pump module assy 420881996 Supercharger Ass'y Exhaust emission component 420867191 Compressor Impeller 420881102 Supercharger Kit Exhaust emission component Fitting Stabilisator 265000014 RH Side Vane lh 277001487 277001486 278002006 Main Harness Ass'y 278001700 Steering Harness 420922686 Water Pump Housing Ass'y 420889720 Magneto Flywheel Ass'y 420889710 stator rotax 664130 664942 664 130 664 942 siemens
4 tec seadoo sea doo gtx rxp rxt 4tec rxppx gti
What do you want for the driveshaft bearing seal? I damaged the rubber seal and now it leaks oil when I run it. I think I just need the part with the seal (I think it's attached to the bearing).
