tresvatos1
I am sure we are all familiar with this problem. I added a $40 gallon of Synthetic oil only to find the bilge full and drive purple coated several days later. After replacing the oil line grommet rear grommet and having this happen again, I decided I needed a different design to fix this problem, as this was becoming a HEADACHE with cost and just general mess of waste oil in the hull. What I decided on was to take a John Deere tractor oil resistant 1/4" to 5/16" fitting , remove the oil tank and thread the existing hole to accommodate the fitting. I then placed gas & oil resistant Seal All around the threads and slightly torqued the new fitting in the hole. I then placed the old oil hose with hose clamp on the fitting after reinstalling the oil tank. I have had this set-up for about a week now with NO signs of any oil leaking from the oil tank on my 99 Speedster.
Does any one see this causing a problem...? Or is this a viable " fix " for this headache grommet setup on this oil tank maybe.
