Hello,
Last year I bought a 2001 gti . Before i bought it the guy told me it had 150 psi on both cylinders. When i got there he showed me the compression, it was 145 on both when we tested it. I ended up having to replace fuel lines and selector valve, & carb kit. After that it seemed to work really well. I goes about 45 mph so that's about all I expected out of it. I took it when we went on vacation to the east coast from ontario this summer. It worked good but would bog down over 3/4 throttle. I figured it was a carb adjustment it needed but since it was only for a week and it would still do about 40 mph I left it as is. I did notice it was harder to start down there having to pump the throttle when it was turning over to get it to start most times. I remembered reading they wouldn't start if their compression was too low in the water so when I got back home I figured I would recheck the compression. Both were around 124 psi. I've had it out on the lake back in ontario and it starts great. Would the hard starting when in nova scotia be related to the low compression? I also tested the compression with a little oil added to the the cylinder and it was right at 145psi. Would the guy have added oil before showing me the compression or could I have lost compression that quickly? I wouldn't have put anymore than 10 hours on it since I bought the seadoo. How low is to low for the seadoo to keep working?
Thanks
Thanks
