Shop Discount Sea-Doo Parts
loud beep after starting both motors
Danosll
Messages
211
Location
Montreal
Water Crafts
1997 challenger 787
1997 challenger 1800
2006 speedster 200 430hp
Hi
on my new to me 2006 speedster 200 430hp immediately after starting both motors (in either order) there is a loud long beep, no mil lights come on . is this normal or is the ecu telling me something is wrong. no mention of it in owner or service manual. performance doesn't appear to be where it should. only revving 7500 rpms
thanks everybody
Lumps
Messages
341
Location
CANADA
Water Crafts
2000 seadoo challenger 2000
a long continuous beep typically means over heating. maybe your water flow is blocked? I think on the newer boats the also do that for oil level too?
Danosll
Messages
211
Location
Montreal
Water Crafts
1997 challenger 787
its immediately after both motors start. no matter which order they are started or how long you wait to start 2nd engine . as soon as both start running ther is a loud long beep.
ID62
Messages
94
Location
Germany
Water Crafts
Sea Doo Speedster 150 155HP (sold)
currently
Sea Doo Utopia 205 310HP build 2006
I guess it's normal, mine do the same.
Danosll
Messages
211
Location
Montreal
Water Crafts
1997 challenger 787
where do you guys usually keep your fuel level. mine is generally below 1/2 .(I have to carry gas cans to my boat.) just wondering if that has anything to do with it.my challenger 1800 let out a low beep when fuel was low. every other level is good
JTR
Messages
50
Location
Ontario Canada
Water Crafts
2 - 2007 GTX 4-tec 155 HP
Yamaha SX-210 Jet Boat 2 x 110 HP
For me it is always the depth gauge, always have to push the reset button. I have a Yamaha SX210, 2 x 110hp.
Lumps
Messages
341
Location
CANADA
Water Crafts
HI all,
Are you saying it beeps one long beep? or are you saying there is a continuous beep the whole time?
JTR
Messages
50
Location
Ontario Canada
Water Crafts
HI all,
For me, start first engine I get a beep, hit the depth gauge button, start second engine, the beep is continuous unless I hit the depth gauge button. I am in deep water so not the gauge itself giving me a depth warning. Jim
enut
Messages
173
Location
Liverpool, NY
Water Crafts
2008 Seadoo Utopia 205, Sold: 1998 Seadoo Challenger 1800
My boat does the same thing. I am thinking that it may be a lo voltage alarm. When the second engine is started, there is a voltage dip on the currently running engine. When it is dark out, watch the batt. lamp for both engines, it will light up for the running engine. Someone with a candoo pro can check if any codes are stored but I do not think that the fault exists long enough to set a code. It is very annoying.
OBDKenobi
Messages
2
Water Crafts
2007 Sea Doo Challenger 180
Is there a diagnostic code on the gauge? Mine was doing the same thing (mentioned in another post) The gauge was showing a 12V message. It was a melted fuse housing.
SPONSORED LINKS
Latest posts
Usergroup
