1976camaro
I have a 2011 GTI 130 that sunk last week. Got a call from the marina it was submerged. After it was raised and water pumped out and engine cleared of water in cylinders. Managed to get it started
We found out the cause was from a clear hose that came loose from the back of the ski. Not sure what the purpose is. There are two tubes that inside the engine compartment take in water and circulate it. The two tubes come out they are coupled to a yellow 90 degree fitting that has a pee hole that also puts a small amount of water in the hull when accelerating. I think they may have something to do with the braking system
I can barely reach to put the tube back on let alone clamp or rezip tie it. Can I just plug it? What is this tubes purpose?
