Looking at a couple older SeaDoos, have a question about compression
mike_dmt
A pair of 96 sea doos came on craigslist in my area for a decent price. They both need minor work and parts, which I'm able to do myself. Not 100% which engines they have, but the owner says they both comp out at 110psi.
He also said they were winterized and have been stored for about 2 years. Could compression drop after that long in storage? What else should I look out for before I drive an hour to look at them?
Thanks in advance!
first 110 will need a rebuild from the get go.... so factor that in ive never had comp drop after sitting unless you put it away wet and it rusted and rings broke ..
Agree with Brock. 110 is low but then again he may not be testing the compression properly with throttle fully open. If he is then plan on a rebuild.:cheers:
K.
If all 4 holes read 110 then his gauge is broken. I just found out the off brand gauge that I was using only read to 150psi. Anything over that still read 150. So that's my 2 cents on that.
A pair of 96XPs is as about as good as it gets. Two of them complete with a double trailer in non-running condition would be worth up to $1500 in my opinion.
Interesting. One is a SP, the other is a GTX. I think the XP is a more valuable machine.
Apparently they both need a battery, (naturally), one needs a throttle cable, the other needs computer work, not sure if thats a mpem or what. Trailer is newer, and could hold 3 'Doos total, with a bit of fabrication. He offered them to me for $1800, so
If you can do work yourself maybe. Still sounds a little high. Low ball it and see what you get him down too.
Yeah, I thought that too. I actually just bought a 92 SPI that needs an engine an hour ago... So Id mostly just be interested in his trailer and his SP. The little ones are more fun..
If they've been parked for a long time... I would fire them for just a few seconds, and then re-check the compression.
I don't normally recommend checking on a "Warm" engine... but if they've been sitting... there may be a light glaze of rust on the rings... or they may be stuck. Starting the engine for just 5 or 10 seconds, will free them up.
Then... check the compression with an open throttle. You want 135 or better, otherwise it's time for a rebuild. (And it's probably why they were parked)
I understand I am on the opposite coast, but cost around the beach here are usually higher than normal. That being said, IMO $1800 is ridiculously high for two skis having a laundry list longer than a normal prestart checklist at the ramp! There are some good deals here on CL and I think you could find better if you wait it out.
Even if the guy tested them at closed throttle, I have never seen a 30-40 psi difference between closed and open throttle. So, other than him letting the piston travel once and only getting 110, I agree with the others on planning on rebuilds. I sure wouldn't want to get a ski in the middle of the season just to be rebuilding for the next month.
Both skis, trailer and 3 clean titles...... I wouldn't mind spending $1k for that package. Good luck with whatever route you take.
