Jet pump oil questions
kelbro
'95 XP, 95 SPi
How do you check the jet pump oil?
How do you change it?
How often does it need to be changed?
What type of oil is required?
Use the search function but....
1. You don't check it you just change it.
2. Remove steering nozzel and remove the two bilts holding the cone on. It will be messy and stinky.
3. Once a year.
4. Seadoo Jet pump oil or Klotz jet pump oil. Some also have used Mobil 1 75w-90 synthetic gear oil.
5. Download the manual for step by step instructions.
