Hi everyone....
I'm looking for some guidance if this sounds more like a fuel problem or electrical problem. Basically I have a Challenger 1800 with twin 787's. I purchased it used 3 years ago with 1 engine not working. I brought it to a dealership who said its an MPEM problem so I had them install a new MPEM, re-time the engines, link it to my DSS key and now both engines work. The problem is I only have a 90 day part warranty on the MPEM so I want to make 100% sure this MPEM is not the cause of the problem I'm experiencing as it was an awfully expensive part to replace.
When I have the boat out on the water it runs great - no issues at all. After about 1 hour of run time the right engine rolls back to about 5000 RPM. Left continues to run without any issues at all. If it let it idle for a bit then i can get the engine up to 7500 RPM again but only for a few seconds before it rolls back to 5000 RPM. If I let the boat sit overnight the next day everything works great again for the first hour on the lake.
I've pulled the carbs and the internal filters were dirty (but not clogged). The rest of the carb (jets, etc.) were all very clean without issues. I've rebuilt everything and its still doing it (although the boat does seem like it has more power). I've also swapped the high voltage boxes on the engines and its still doing it. I'm considering swapping the carbs and rectifier tonight too but to be honest I feel like I'm just guessing in the dark here.
Any advise would be GREATLY appreciated here - specifically - any advise on
i. what i should test next
ii. what can i test to help me confirm if this is a fuel or electrical problem
iii. any tests I can do on the water when the issue happens to further narrow it down
Many thanks as always for everyones contributions
