M MJennings21 New Member Sep 28, 2016 #1 I just replaced my starter solenoid with a new one I ordered off Amazon (probably not the best choice). Every time I try starting my Seadoo all I get is a single tick which is the same problem from before.
Coastiejoe Moderator Moderator Sep 28, 2016 #2 Jump the solenoid. If it still just ticks, then you have a bad battery, cable, cable connection, or starter. If it cranks fast as it should, then test for 12 volt at the trigger wire of the solenoid when pressing the START button.
M MJennings21 New Member Sep 28, 2016 #3 I'll try jumping it when I get back home. I already tested the trigger wire and it gets 12 volts
