black charger
This past weekend my 95xp started stalling.I felt around under the carbs(was feeling for LS screws)and found the cable for the oil injection had come off of the carb linkage.I read on another post that if this happens the oil pump will pump oil at full volume(could explain the stalling).I hooked it back up and it seamed to start OK,I added oil to the gas just in case.Now I don't trust the injection system and would like to convert to premix.Can I just disconnect the cable and run like that or do I need to take it all apart and block everything.off.Seems kind of complicated to do.Wouldn't gravity from the oil tank keep the pump lubricated and I just plug the lines into the manifold.
