GregSr
Well, it finally happened. I had read other horror stories of seized impellers. It finally happened to me. My 98 SeaDoo Sportster was running great as my son and I were taking a few quick laps around the lake.
Then suddenly engine #2 (starboard) just stopped. No warning, no sounds, just zero RPM. Pressing the starter button just produced a clunk sound. We brought the boat home and began investigating. Pulled the head off expecting to find a seized piston. By grabbing the flywheel and trying to turn it, we could see the pistons trying to move. They were fine. Then we pulled the cone off the impeller tail shaft. Bingo! There's the problem.
It was obvious that the cone had lost its oil and the bearing burned out...allowing the impeller to seize up. With the cone removed, the impeller shaft will not budge. I serviced the cones last year but apparently did a poor job. BTW...we pulled the cone on the #1 (port) impeller and it was perfect. Full of clean (smelly) oil. Although I used locktite on the cone screws, somehow the screws had loosened and let water in and oil out.
Here's the question. What now? I have no idea where to go from here. I've never done service on any impeller.
Any suggestions or advice would be greatly appreciated.
Thanks in advance,
Greg
Thanks in advance,
Greg
