benjilafouine
Hello,
I rarely write in forums but this time, I am scratching my head hard.
Almost 2 weeks ago, my Sea-Doo GTI LE 2003 started acting strangely: the motor would cut (like if there was water in the gaz but all filters look fine). Then it ended up with a little bit of water in the engine after my passenger (not sure) tilted the machine. Then it started having clicking sounds when I was trying to start it. Note: I bought the sea-doo a few months ago from a relative who took great care of it and it ran for 25 hours without any issues.
I emptied the water by removing the plugs, grounding the wires and starting the engine with no plugs: some water came out and I was able to restart the sea-doo despite the solenoid being fried.
I brought to the local sea-doo mechanics here (no BRP dealer around) and he found that the ground attached to the motor was loose. He fixed it and changed the solenoid and then I went to test it on the lake.
It ran fine for one hour and then it died abruptly (the motor just stopped) and despite I could crank it, it would not start.
So I brought it to a sea-doo dealer and here is what he did:
- Made a new key (because min was pretty worn out)
- They were able to restart the motor but it had so "strength". When they would press the accelerator it would stop.
- So they check compression and it turned out pretty good a 124 hours motor: 135 in one cylinder and 130 in the second one.
- So they removed the carburetor completely and cleaned up the whole thing (two hours of work).
- While being there, the changed the turbine oil and everything was in order there (I presume).
- Then they tested the machine with a water hose and it would start just fine and they tested it a few minutes. They changed a few o-rings here and there and they told me the sea-doo is just fine (for its age).
Brought it back to the lake this morning, put it in the water, started it and it started just fine. But since I had all these troubles in the past two weeks, I stayed very close to my place. Good thinking because after two minutes running, the motor experienced a sudden loss of power. I was able to bring it to the shore where the motor stopped by itself (again). Then impossible to start it.
Brought it out of the water Still not starting. It was working one hour ago and it dies in two minutes while testing it.
What is going on? Anyone has a clue? The only test I didn't do is checking the plugs for fire but I am not too sure how to safely do that.
Thanks for helping.
Benji
Thanks for helping.
Benji
