hull leak
leet66
I have 1999 gtx limited and it is taking on water. I found where it is coming out after I filled it up. There is small drip coming from the inlet plate where the inlet grate attaches, was wondering what likely needs replacement once it is taken apart.?
Can you tell that it is coming from the grate, or could it be dripping to the grate from the drive shaft area?
After more detailed search it would appear to be dripping from the main housing of the propulsion or at least that is whereI am see a drip.
