If they are glossy... either the plugs are....
1) Too cool for the engien
2) Too much oil
3) Way too rich
4) low compression
OR...
5) You ride your ski like an old woman, and you aren't burning them clean. :rofl:
after I get a shower... I go pull a plug out of my ski and post a pic. You read them after pulling them out. Don't wipe them.
Last thing... if the plugs are old... don't try to read them. If you want to "Read a Plug"... then put in a new set... go ride for an hour or so... and check them. You can target an RPM range... but you need new plugs... hold the throttle at the RPM (this is in the water) then chop the ignition without releasing the throttle. But if you need that kind of tuning... then a wide band O2 system is what you want to use.
