Sofla
Ive been reading about the carbon ring and what it can cause symptomatically. In hopes of identifying the same problemic sound i get as the latest issue. Seems to be only in gear.. and once accelerating off the idle speed. I can best describe it as a arbitrary clang ; bang with a notable lack of power and the impression that someone is hammering the bottom of the boat.
Imagine sucking up a tie down strap... the hook banging around... thats what it almost seems like. I inspected both the bottom shaft and intake as well as from the rear looking into the pump at the impeller edges... and again nothing obviously there.
Is this the only source of such a sound? Also i noted that when i pushed the throttle the last time i was tinkering... in the water... it felt like almost nothing, but again at idle it putts along seemingly okay.
Any advise... and ideas... i tried pulling the grate below to get a clear look at it, but found the bolts to the grate would loosen but not pull out. They are not thru bolted and seem to screw into the bulkhead wall of the bottom itself right where the pump cutout sits ..? Once insaw this i hesitated in fear of not getting it tight again. Which seems the case now. There is plenty sndsolid black seal holding ; but the bolts turn and dont tighten down fully. Could i have accidentally caused a leak point with these bolts and where do they seat actually?
Had the whole family set to go today and it would seem that its not going to happen today
Any guidance is welcome and appreciated.
Many thanks
Many thanks
