jcturner21
Good evening,
There are two visible holes (by design) on the starboard side of my 99 GTI Seadoo (717 engine). There is another hole that is hidden behind the plastic cover also on the same side of the seadoo. The hole by itself has a fuel line hose that wyes together with the one of the two visible holes and make their way to the fuel tank air intake. The other hole has plastic tubing connected to it and I just found out that it does not terminate anywhere inside the seadoo but found it near the rear of the seadoo open ended while I was tracing the bilge lines. Can this be correct? I thought this was supposed to spit out warm water from some component connected to the engine?
thanks in advance!
Jim
thanks in advance!
Jim
