I have a 2006 Sea Doo Islandia. Two of the non-SC 4-tec engines.
At idle/low throttle, all is normal. Getting the minimal thrust from both pumps.
At higher throttle, the port engine revs very high and yet no real change in thrust. Starboard engine/pump is performing fine.
Hav searched and read the forums here. I don't have anything stuck in the impeller, etc. etc.
It just started happeninthe last time I drove it... although the boat sat in fresh-water for about a month (with no use.) I didn't hit any logs or sticks or rocks during the prior outing.
Attach is a picture of the impeller. Very minor damage to it. Boat has only about 60 hours total on it.
So, IGNORING ALL THE OTHER possibilities of what could be causing it: Could THAT SMALL amount of damage ALONE cause such a major loss in propulsion?
