derekk
My Challenger 180 radio doesn't work and also the isc and blower don't seem to work either? I took the fuses all out and they are all good. So I took out the fuse block and did some testing on it.. I'm not a mechanic or electrician but I did some ohms testing on the pins that are for the fuses. There is not much feed back from the pins on the right hand round pins to the last 2 fuses that I believe are the radio and blower(noticed they are labeled wrong). Also I did some checks on the fuse spots with my test light and only the top hole of each fuse lights up.. is this normal? I also put my test light on the plugs that hook up to the fuse block and only one of the pin holes lights up out of all of them this doesn't seem normal but I have no idea.. Anyone that can help please let me know.. Thanks
