theforce220
Ok, Maybe someone out there in computer land can help, I have a 2005 Seadoo 3d with the Rotax 782, last year while thoroughly enjoying my ride, unknown to me the battery strap had worked loose and my battery spilled over onto my block knocking my oil resevoir line off as well as breaking 2 brass nipple fittings. Here inlies the problem. I need to order those 2 brass fittings but seeing as I live way out in the middle of nowhere my closest Seadoo buddys are a few hour drive away so.... above the throttle body there is 2 small oil/fuel lines that come from the back towards the front and attach to brass nipples actually into the top of the throttle body. any help with finding out where and how I can buy these 2 little brass nipples would be a life saver. If you need any further explanation or some pictures I may be some help!
Thanks
Thanks
