Having issues with acceleration on the water
pepe2626
Hi all
I am having problems with my ski accelerating. I hit the throttle and it goes but not as fast as it should be. I replaced the wear ring, spark plugs,mpem, solenoid, and fuel line but am still having the problem. Does anyone have any suggestions as to what I could do to fix this. I am getting super frustrated am have been told that the problem should have been fixed by replacing the wear ring. Please help!
Thanks
Hi all
Thanks
You check the compression?
how do i check it
Go to parts store and get a engine compression tester. Remove your spark plugs, screw it in the spark plug hole and spin the engine over holding the throttle wide open and stop when the pressure stops going up on the guage. Repete for each cylinder. Report back with the numbers.
I have done exactly what you said to do & When i try to turn the driveshaft, Its really hard like if it cant be turned. I was turning it by hand but Can i start up the engine or no ? I still have the compression kit so lemme know fast !
I just did it as shown in a video, The compression came out to 135 each , They're both the same . What now ?
