peter Nosbor
The ski does not run well above 3,500 RPM. Both cylinders have spark and my mechanic tells me that the timming is not advancing.
We have checked the crank - it is true, we have checked the flywheel and associated keyway, it is as per specification.
The VTS recently blew its fuses and I have disconnected it - don't use it anyway.
Is this a problem to do with the MPEM?
What are my options - I don't fancy buying a spare unit at over $Aus 1,000 unless this is the problem.
Is there a way to test the MPEM to see if this is the issue.
I see that second hand MPEM are available.
Does anyone else have these types of problems and give advise on replacing the MPEM?
