I was winterizing my 2008 RXT this weekend and after fogging the cylinders and putting the 2 fuel rail bolts in the one seemed like it stripped. I tightened it by hand as much as possible so i don't think the bolt stripped. I am not sure if the sleeve that's molded into the manifold slipped or if the bolt itself stripped but i can not remove the bolt to even take a look.
Anyone run into this issue? And how did you fix it? Any ideas how to remove the bolt without grinding it off?
Thanks.
Thanks.
