fouled plugs and propulsion problems please help!
kennedy0331
I have a 991 gsx rfi seadoo waverunner, bought it a month ago with a broken sterring rod got it fixed took it out the same day started right up and took off perfect then started boggging out, thought it was bad gas and checked the spark plugs and they were fouled then bought brand new ones and added octane booster to help it run better, put it back in the water ran perfect for 3 days strait even with pulling my buddys on a knee board then the 4th day it was acting weird, took awhile for it to shift into gear then all of asuden went back to bogging out and wouldnt go past 30002 rpms which is like basicaly idleing checked the sparked plugs fouled even worse then before rode it back to the dock and it was smoking like crazy then it just shut off, people are saying my wear ring on my prop is bad, some say my gap on my spark plug is bad some say my oil injecotrs are bad and the motor is getting to much gas and idk what to do anything helps thanks
Welcome to the forum. From what you are saying, it's not a propulsion (wear ring/impeller) problem. What 2-cycle oil are you using? Not sure how the RFI's regulate the oil mix. Try posting your question in the 2-stroke PWC section.
Where in Florida are you?
