SPEED18
Faint double click and no turn over
97 xp will not turnover. Had it out for a test run on thursday everything was fine untill i did a couple of 180's with it and had some water get into the front. Noticed the the seal had shunk about an inch. Let every thing dry out and tried it on friday and nothing.
I am getting a very faint 2 beep sound more like a double click. Replaced all the fuses including the the 15 amp thats with the starter n cellinoid. Got the double beep to work but that was it. Ran to the hardware shop to grab some electrical contact cleaner. Cleaned the connections where there was a bit of corrosion. Now i've lost the double beep and the faint double click is all i get. is there anything else i should be looking at??
