F1 Fuse - Fuel Sending Unit
opeter
Messages
6
Likes
0
Water Crafts
1999 GTX Limited
#1
OK, I know there are a TON of threads on this issue, but I can't seem to find the exact answer I'm looking for.
I have a 99 GTX limited with bad fuel gauge. Float is good. Tested with OHM meter and there was NO change in output as float slid up and down sending unit.
Seems like it's the F1 from what I am reading. I cut my sending unit, but didnt see the 250ml fuse that is referred to so often in threads. Do I need to cut the other side? or do I solder what I see in this picture. Here's a picture of what I am looking at, with F1 clearly marked. Sorry, I'm new to this stuff, but seems like it can be fixed. Any suggestions are appreciated. Thank You
mikidymac
Moderator
Staff member
Moderator
Messages
8,932
Likes
634
Location
California
Water Crafts
2003 GTI
2001 XP
1997 GSX
1996 XP
1996 HX
1996 SPX
01' Superjet
#2
That little thing with your "?" is the F1 fuse. Use a soldering iron to remove it and jump the contacts with solder.
opeter
Messages
6
Likes
0
Water Crafts
1999 GTX Limited
#3
OK, thanks. So that little square thing is the actual F1 fuse? I wasnt sure, since it looked so different from all the other pictures I saw posted online. Any tips on soldering? Any specific kind? and should I flux.
Thanks again
mikidymac
Moderator
Staff member
Moderator
Messages
8,932
Likes
634
Location
California
Water Crafts
2003 GTI
2001 XP
1997 GSX
1996 XP
1996 HX
1996 SPX
01' Superjet
#4
Just use rosin core solder for electronics.
opeter
Messages
6
Likes
0
Water Crafts
1999 GTX Limited
#7
Thanks for the image. Looks like I'll cut my opening bigger like did.
Did you use the Rosin Core Solder like mikidymac suggested?
L111DDN
Messages
23
Likes
0
Water Crafts
Seadoo GTX Millennium edition
#13
Got it on order so just waiting for them to be delivered. Will send a picture when I’ve done it
L111DDN
Messages
23
Likes
0
Water Crafts
#16
Looks like the exact same fuse holder I ordered off ebay, for me it was like 5 for $5 shipped. May be the pics, but those fuses look like mini glass fuses... the fuse holder looks a regular size..
Your right the fuse holder is 30mm and the fuses are 20mm ‍♂️
opeter
Messages
6
Likes
0
Water Crafts
1999 GTX Limited
#18
Update.
I took out F1 and bridged the gap with solder. Gas levels are now working! Thanks for all the advice. Now on to the next issue.... ski cuts out randomly. I’ll probably post a new thread.
Thanks again all
Adsense
Usergroup
