Hello everyone, not sure if I should be posting in this thread, its my first but here goes. I have a 2000 seadoo GTS , the engine keeps cranking. So far I tested it with the start on off switch off, still cranks, I tested it with the front wired disconnected to the Starter Relay switch, and it stops. I removed the red wire from the starter solenoid to the mpem with the front wires re connected to the starter solenoid switch and it stops. Replaced the starter solenoid switch still keeps cranking. Is my MPEM that is bad? If so can it be bypassed?
