Engine Component ID help
Messages
4
Likes
0
Location
Greenville SC
Water Crafts
97 SeaDoo XP and 98 SeaDoo XP Limited
#1
Hi Guys! New to the forum and looking for help to ID a part on the engine. What are the black cylinders with the red dot called? Thanks in advance for your help. 252EC19D-5D3A-4478-B311-BFEEE723AA88.jpeg
JJinSC
Messages
1,147
Likes
15
Location
SC
Water Crafts
1997 Sea-doo XP
#2
That is the RAVE valve covers. Under higher RPMs the valves slide to open the exhaust ports wider.
riffe723
Messages
356
Likes
33
Water Crafts
(2) SeaDoo SPX - 1997 (sold)
SeaDoo Speedster SK - 1999
(2) SeaDoo Spark 90hp - 2016
#3
Looks like that top end got hot or something.
Messages
4
Likes
0
Location
Greenville SC
Water Crafts
#4
Thank you for your help! I just noticed one of mine is cracked and needs to be replaced. I assume you can find these parts pretty easily on Amazon and what not...
JJinSC
Messages
1,147
Likes
15
Location
SC
Water Crafts
1997 Sea-doo XP
#5
Yes, pretty easy to find. Go ahead and take caps off and inspect the rubber bellows for cracks,etc. you’ll probably want to pull the guillotines and inspect clean
Messages
4
Likes
0
Location
Greenville SC
Water Crafts
#6
Will do. I had a XP when I was younger and just recently purchased 2 XP’s to play at the lake so its been awhile since I have worked on them. What part of SC are you from?
JJinSC
Messages
1,147
Likes
15
Location
SC
Water Crafts
1997 Sea-doo XP
#8
I’m in the grand strand area.
SPONSORED LINKS
Usergroup
