Engine Alignments
etemplet
Messages
1,592
Likes
116
Location
Louisiana
Water Crafts
1996 SPI, 1996 GTX, 1997 GTX
#1
I am curious as to how many jet ski engines are actually in alignment. I bought and alignment set up last year from a Green Hulk Board member in my area which I have used about 1/2 dozen times so far. My biggest concern is angular misalignment and it is the most difficult to detect using the tool. I would be interested to hear from members on the subject.
mikidymac
Moderator
Staff member
Moderator
Messages
8,946
Likes
637
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
#2
I have only checked a few that never had the engines out and they were pretty close but not perfect. The theory is that the hulls bend, flex and settle over the years changing the factory alignment although the factory might have not had them perfect either.
riffe723
Messages
311
Likes
28
Water Crafts
(2) SeaDoo SPX - 1997 (sold)
SeaDoo Speedster SK - 1999
(2) SeaDoo Spark 90hp - 2016
#3
I was curious about this as well. My 96 pump bearings are shot, previous owner used an angle grinder to sharpen the impeller. I believe when he did that, it was never aligned and that's why the pump bearings are shot, the shims that go on the pump studs were missing as well. He also used and extremely unnecessary amount of silicone when he put the pump back one. I've checked alignment on one that I know hasn't had the engine out of it, similar to miki result. They were close but not perfect.
etemplet
Messages
1,592
Likes
116
Location
Louisiana
Water Crafts
#4
Bet the imbalance on the impeller accelerated the bearing damage. I have not yet come across shims on the pump studs or shims anywhere around the pump. Is that factory? If so....why?
riffe723
Messages
311
Likes
28
Water Crafts
#5
There definitely are shims on the pump. As to why, I couldn't tell you. Manual says to place pump shims where they were take from.
etemplet
Messages
1,592
Likes
116
Location
Louisiana
Water Crafts
#6
Or we talking about internal jet pump ships or shims between the pump housing and the mount? I mentioned "pump studs." Just making sure we are on the same page.
etemplet
Messages
1,592
Likes
116
Location
Louisiana
Water Crafts
#7
I would enjoy a tour of the factory so I could witness just how accurately they do things. That information gets muddled over the years. Factory alignment may be.... if you can slide the bar in without much pressure... it's close enough. LOL
mikidymac
Moderator
Staff member
Moderator
Messages
8,946
Likes
637
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
#8
On the older skis the shims were on the pump studs to get it straight then final alignment was done at the engine.
On the newer ones with the plastic pump shoe/plate the shims are between the plate and the hull so you will not see them unless you replace the plastic shoe/plate.
Adsense
Usergroup
