Eek! fuel into oil!
vilord
Okay, I was wrong, the fuel selector is connected properly to on and reserve.
But the carb fuel return doesn't go to the fuel tank, it goes to the oil reservoir! :ack:
What was this guy thinking????!?!? (Previous owner, a real winner)
How much fuel comes out of the carb return line? Do I need to dump the oil and replace?
Also, where does the oil return line connect on the engine? Is it near the carbs? I'm having trouble reading the diagram and finding the wire... :confused:
Thanks!!!
Okay, the oil return is in place, the smart-guy attached the fuel return to the *wrong* side of the one-way valve on the oil reservoir vent. See picture, what a winner!
Any thoughts on whether the 1-way valve held up to the fuel pressure? What should the oil smell/look like?
I would just dump the oil in the reserve tank and add new to it. It is possible that the gas made it into the oil and diluted it slightly. That means it will be at a lesser oil ratio then you want. Use seadoo xp-s synthetic oil. That is what's recommended to use in your seadoo. If the old owner used something else let me know, but that is the oil that is recommended.
Karl
I have no idea what the previous owner used. In fact I think he didn't even ever fill it, he just used whatever the guy *he* bought it from used (only used it 3 or 4 short trips before parking it).
Would it be bad to switch to synthetic if the old stuff is mineral based? I'd rather use the good stuff, 50 bucks a fillup is cheaper than a new engine every two years.
Here is a step by step to the oil pump oil lines;
After you drain the oil from the oil lines and refill them, you have to be sure there is no air in the lines when the engine starts up or it will cause the engine to seize up. You need to fill the oil lines back up with oil. To drain the oil from the Rotary Valve Chamber, use a shop vac to suck the oil out of the hose…it’s the one that is 3/8” diameter. I attach the empty lines back to tank and fill the tank. The oil line going to the oil injector pump attaches to a elbow fitting on allows the oil to flow to the pump. I let the oil drain into the oil line to the pump first and put a small cup at the end of the oil line, to catch the oil coming out of the end of full line. Attach the full oil line to the elbow on the oil pump. There is a bleeder screw on the pump. Lay a rag under the bleeder screw. Open the bleeder screw till the pump has oil coming out. Tighten the bleeder screw. Be sure the oil is full in the small 2 lines also. Let the oil seep out the ends of the small lines to fill the lines as best as you can. Connect the 2 small oil lines from the pump to the carburetors. Where the cable is connected is a Disk,(pump lever) that the cable is attached to. Check that the mark on the pump aligns with the mark on the disk. Apply the throttle with the ENGINE OFF and check that the cable is in sync with the oil injector cable. They should move open and close at the same time. To bleed the 2 small lines and get the bubbles out, start the engine, on the water hose. DO NOT APPLY THROTTLE. Let the engine IDLE. Turn the Disk,( pump lever) that the oil injector cable is attached to, to full open so the air bubbles travel to the carburetors and leave no bubbles in the line. Don’t run the seadoo for more than a couple minutes on the hose.
For the Rotary Valve Gear Shaft, attach the hose on the tank and allow the oil to fill the hose and attach it to the case. Recheck all the oil lines and be sure they aren't leaking any oil. If you still have any questions give us a shout.
Use the Seadoo XP-S synthetic.
Karl
