Polcat
Is the impeller supposed tospin freely? Also I know I have a rock in there and it has since been removed. I wonder how it got in there
Ok. It does not spin freely with A long screwdriver I can get it to move an inch or two and that’s about it. I figured it would spin freely but I guess it’s good that it doesn’t. I’m at answers as what could be wrong. Could it be my throttle cable? Thanks
Its still in. I just took the end piece off, As I was only being held in my one bolt. as it was only being held in my one bolt I just want to get four more bolts and put it back together and see if that was my problemIs the pump still in the boat?
If it is out then it should spin freely.
If it is installed it should not.
I assumed it was out.
if that utopia M2 240 has the same pump setup as my 2002 challenger M2 240- it doesn't have a replaceable wear ring like the rotax engines have- it's a one piece machined aluminum part- I was never able to find any after market parts for my M2 jet pump- you may find used parts in good shape on ebay. in the $1500 - $2200 range. It's one of the reasons why I stay far away from the old challenger M2 boats. I've owned 3 of the 240 M2's and nothing but expensive issues. If the wear ring isn't too bad, you might be able to have it cleaned up. You won't find any Mercury M2 parts from Seadoo because it's not a Sea Doo product, it's a mercury product. Here's the entire pump assy on ebay- price isn't too bad considering you're getting the whole jet drive-Is it cheap to replace the stator and wear ring with a brand new unit? I cannot find any part numbers anywhere. Or prices
