Shop Discount Sea-Doo Parts
Display is blank
Messages
5
Likes
0
Location
cape coral, fl
Water Crafts
1996 yamaha wave runner
2004 kawasaki
2016 sea doo spark
#1
I have a 2016 spark. it has been sitting for close to a year with the battery removed. I need to replace the pto(?) (gears in engine that drive the drive shaft) and have not had time to do it. I went out today and reinstalled the battery (full charge). After 15 minutes of cranking it it finally started and ran good (just ran it a new seconds). However, I was confused soon as I put the battery in because I thought that when I connected the key it would beep 2 or 3 times, it did nothing. I also thought the screen came on, also nothing. Any thoughts as to why it does not beep when the key is attached and why the screen does not turn on?
Ckrawiec
Messages
590
Likes
92
Location
Rochester, NY
Water Crafts
1996 GTX, 2017 Spark 2up
2018 GTS
2006 Bayliner 185BR
2019 Misty Harbor 22' pontoon
#2
It's possible that corrosion has set into the connectors to the display....have you checked all the wiring? I know its a royal PITA by having to take the top deck off, but the ski should wake up if you install a good battery and push the SS button - a welcome message should display, so you don't need the key to wake the ski up.
Messages
5
Likes
0
Location
cape coral, fl
Water Crafts
2004 kawasaki
2016 sea doo spark
#3
Ya, when i press the button in the display area, it does nothing. Do you know how to unplug the plug in the back of the display? Looks like there is a red lever. It doesnt move easily and didnt want to force it when im not sure what way it goes. Looks like it might pull out. Thats if its even a lever/lock. Any idea???
Ckrawiec
Messages
590
Likes
92
Location
Rochester, NY
Water Crafts
2018 GTS
2006 Bayliner 185BR
#4
I believe the RED thing is the connector lock...you need to pull that back and then the connector should release...they can we "difficult" sometimes but they do release (they don't disconnect from the plug though so don't try to remove it, just pull it back)
benjilafouine
Messages
1,544
Likes
61
Location
Lac-Simon, Quebec, Canada
Water Crafts
Sea-Doo GTI LE 2003, GTI 90 2018
#7
Then corrosion could be the issue especially that you did not use it in a long time. I am not sure how you clean/wash/spray the inside hull on a Spark but saltwater is definitely a killer.
Messages
5
Likes
0
Location
cape coral, fl
Water Crafts
2004 kawasaki
2016 sea doo spark
#8
I'm trying to localize where the problem could be. There are lots of clues for you experts that know the wiring. It starts and runs when the key is attached but attaching the key does not beep twice and at no time does the display show anything. The big plug that I unplug to remove the top looks clean. Wont be home till tomorrow to try and unplug the display plug to look at it (on a 48hr shift)
Ckrawiec
Messages
590
Likes
92
Location
Rochester, NY
Water Crafts
2018 GTS
2006 Bayliner 185BR
#9
There are not that many electrical connections on a Spark and you can reach most (if not all of them from the access cover on the side of the ski - mostly), however, since you say the main connector inside the ski looks ok, then that is pointing you to the actual display guage itself most probably....it is exposed to the weather most of the time after all. You may still have to remove the top deck though as the guage is part of the upper deck assembly and I don't think you can access it from the top side (but I haven't had to do anything to my guage yet, so I'm not 100% sure (although I've taken my 2017 Spark apart a couple times already for other things).
Messages
5
Likes
0
Location
cape coral, fl
Water Crafts
2004 kawasaki
2016 sea doo spark
#10
Does anyone know the pinout of the plug for the display? I unplugged it today and there seemed to be a little moisture in there and I want to test the cable for power.
Users who viewed this discussion (Total:12)
SPONSORED LINKS
Latest posts
Usergroup
