Display Gauge
Botello
Messages
4
Likes
0
Water Crafts
Super charger 2003 GTX 4 Tec
#1
Hello.. I have a 2003 GTX 4-Tec and my RPM, Speed and Digital display are dead... I saw some humidity inside the display ... I do not know how to remove it to check if there is a probem with the connection... can someone explain me how to remove it... I already remove some screws form the black part that is under the hood but this black cover is not coming off... is this the correct way or the display should be pull off from the front part... I do not want to brake it.
thanks,
Sergio
ski-d00
Messages
2,301
Likes
73
Location
St. Marys, Ohio
Water Crafts
2012 RXPX
2012 GTR 215
2006 3D DI
2008 Challenger 230 430HP
#2
Just wiggle and it will pull out. You will have just enough room to reach behind it and release the connector.
benjilafouine
Messages
1,220
Likes
32
Location
Lac-Simon, Quebec, Canada
Water Crafts
Sea-Doo GTI LE 2003, GTI 90 2018
#3
These things are weather sealed. On my old GTI I had a little bit of humidity a few years back but a complete winter in my heated garage took care of it. I have also seen a thread on this forum where a guy showed a picture and the gauges were barely readable due to an excessive amount of humidity (literally drops of water behind the glass/plastic). I remember that someone told him they could be opened, but hardly.
Is your still working?
Botello
Messages
4
Likes
0
Water Crafts
#4
thanks to all for your comments... I will try to see if I can pull it out without breaking it ... a black hard plastic is around this display and I do not know if I will need to remove it first .. it looks like this plastic comes out first if I use a knife or a sharp screwdriver ... is this correct or do I need to remove the entire display as a one piece?... I saw some humidity and now I do not see anything due to the hot weather but is not working at all... the display and analog gauges are dead.... I'm an electronic guy and I would like to see if I can fix it to save some money., your recomendation will be very apprecitated... thanks!
ski-d00
Messages
2,301
Likes
73
Location
St. Marys, Ohio
Water Crafts
2012 RXPX
2012 GTR 215
2006 3D DI
#5
You don't need any tools and definitely not a knife. Just wiggle and pull and the whole assembly will come out. It will take some force but it will come out. It is only friction fit.
Users who viewed this discussion (Total:17)
Adsense
Usergroup
