Crank bearing
Anyway of getting this bearing sleeve off, the bearings came out in pieces when I separated the case ?15673641903518644693588322218530.jpg
Had one like that before. A gear puller will get it. The type that is split that uses two bolts to bring the two halves together. You can use the bolts to wedge the two halves of the puller behind the race then attach the actual puller and pull it off.
You are going to be much better off getting a remanufactured crankshaft.
As said above once one bearing goes there’s a good chance the others are going also.
Yeah these guys are right. If it was that way when you split the cases that motor need a complete rebuild with new crank.
