IDoSeaDoo
Well everyone, I've finally begun repowering my Challenger. The donor is this 03 GTX S/C, and the recipient is this 97 Challenger 110. I've blown my last 787 in this baby, and will either repower it with a real engine or just get rid of it altogether. I absolutely love this boat and for financial and aesthetic reasons refuse to get the newer 15' boats. So here we go.
So far, I've pulled the old motor and cleaned up the engine bay of all the grease and grime that built up over the 100 or so hours that I used it last season. That Amzoil is some sticky stuff! I measured the space between the thru-hull fitting and the tip of the fuel tank and it seems that I have 26" of room. Measuring the 4tec, it also appears about 26" from the rubber driveshaft cover near the PTO to the tip of that electrical connector on the cooling assembly. I measured the intake channels on the bottom and they both measure 5", so no problems there. I'll just have to widen the 140mm outlet to 155mm to accommodate the new pump. Might even get to keep the weedless system
I wish the new skis came with a way to adjust trim as I'm pretty sure this boat is going to porpoise a lot when I'm done.
Before I pull apart the GTX for the rebuild, I want to make sure it's running tip-top. It's got 200hrs on it, but seems to have been well maintained by pro-shops. It runs smooth and strong, but used to cavitate badly. The old wear ring had deep grooves in it and two of the trailing edges were bent, one badly. I got a new SBT wear ring, and sharpened the leading edges on the impeller. I noticed that the wear ring wasn't quite round, and that at one spot it was out of spec. I decided to try it anyway, but saw that I lost 5mph. RPMs were 7600, but I was only doing 54 max. Unacceptable, with the bad ring, it did 58. I put an SBT reman impeller on there and will try again, but I'll probably end up shipping that wear ring back to them with the core impeller. I'm really curious to see what this ski will do with a perfect pump.
