ceck engine p0127
pabblo
hi guys
rxt260rs on my 2010, I replaced intercooler (aftermarket), I went to sea, and after about 1 hour I get p0127 ceck engine.
I go to my mechanic, problems in diagnosis appears intercooler, which we replaced about 20 hours
however, I reset the ECU, I go to sea, and after 5 hours ceck engine p0127
Now I changed the temperature sensor I went to sea I did everything ok 3 hours ...
What should I check if it should reappear
I apologize for my language is not perfect
I'm Italian and I write with google translator
I would check the connection to the sensor and make sure nothing was damaged when you installed the aftermarket intercooler.
ok, it's the green one?
Now I replaced it with a new one,
I did 3 hours of sea, everything ok
if dinuovo reappears, I wondered what should I check?
I hope it is that,
hello guys,
then I made 2 days at sea, after changing the sensor,
a total of 7 hours,
the bike okay, not even a hint of light, we hope to have resolved
thank you all
I inform you in case of problems
