SurfBeat
Carburetor Impulse Line
As many of you members know by now, this Shade Tree mechanic recently had to dismantle a 93 GTX (580cc) engine to replace the crankshaft (CS).
As those that have preceded me in a similar endeavor, the project requires a complete engine removal from the hull and a complete engine dismantle, sans the Rotary Valve.
Now that I: 1) replaced the CS; 2) assembled the engine; 3) dropped the engine into the hull; and 4) connected all the requisite electrical components that had been disconnected to remove the engine from the hull, when I crank the engine - no fuel is being delivered to the carbs.
As a matter of background information: 1) I put in a couple (2) gallons of mixed gas; 2) ensured that the gas lines were clear of any obstruction; 3) qua-tripled checked that the gas lines are on the correct carb nipple, confirming (2nd opinion) with Dr. Honda's input on that factor; 4) and followed the Snipers advice to place a plastic bag over the flame arrestor to get maximum vacuum.
Reading a post by Voodoo to a Thread posted by another member, Voodoo suggested that sometimes, during an engine rebuild, the mechanic fails to properly time/align the Rotary Valve, the end result preventing the impulse valve/line from properly doing its job, providing suction for the fuel pump from the engine.
(If I did not quote Voodoo verbatim and accurately, I apologize. I am endeavoring to combine Voodoo's post with others whose names I cannot recall to my specific situation)
Moving on, following Voodoo's opinion, I disconnected the Impulse hose line from the carb to check for suction.
In my case, albeit I did not feel suction, however, I did notice smoke blowing through the Impulse line.
Does that indicate that my RV was properly aligned and I should be looking for another reason fuel is not being sucked into the carbs? (I don't want to go through the hassle of removing the RV cover because one bolt is very difficult to get to.
If yes,regarding looking for another source of the problem, any suggestions will be greatly appreciated.
If no, please elaborate.
