Carbon Ring Seal Replacement Question
JPass
Messages
1,010
Likes
95
Location
Orlando, FL
Water Crafts
2012 Challenger 210 SE
#1
So our boat is 6 years old a buddy of ours with a 2012 Speedster just had his carbon ring fail this past weekend. Ours leak a little at the moment, so I wanted to replace them (we have twin motors) sooner rather than later. Then I began looking into the kits.
I always prefer to go OEM as much as possible, but there's a huge difference in price between aftermarket kits and the OEM ones. OEM is roughly $400+ compared to $150 for aftermarket.
Looking for some feedback on those who've replaced theirs with OEM and the aftermarket kits. Considering we just dropped $500+ on a new cover, the aftermarkets will be much easier on the wallet, but I don't want to go cheap and regret it.
Here's a pic of one of the seals as it sits today. Being that the clamps aren't the factory ones, I'm assuming the previous owner may have swapped them out already, but not positive.
Messages
96
Likes
13
Location
NC
Water Crafts
2005 Sea Doo Speedster 200
#2
Interested in feedback on this as well. I am not currently having problems with leaking, but for a winter project, given the age of my boat, I think it would be a great idea to replace the carbon ring seals and the wear rings in the pumps. I'll be over here with a bag of popcorn waiting for a good opinion on aftermarket rings....... ;-)
Dr Honda
Moderator
Staff member
Moderator
Messages
19,172
Likes
485
Location
Pittsburgh
Water Crafts
'00 Polaris Genesis
'96 XP800
'02 Islandia 240 EFI
#3
In my experience... the aftermarket Stainless rings are OK. Actually, there is a thicker one that I feel is better than OEM. (seals up better) The boots are hit and miss, but most are OK. The carbon ring them selves... well... I only use the OEM. Over the years, Ive seen too many aftermarket versions crack, or wear prematurely.
Since your boat is only 6 years old... I would bet you only need to replace the carbon ring. I'm guessing the boot and stainless ring are still OK.
As far as the price... it seems like the 4-tech versions are more expensive than the early rings, but I'm sure if you shop around you will find them for a good price.
Messages
65
Likes
8
Location
Indiana
Water Crafts
Sea food xp, Yamaha wave runner, sea doo challenger 210
#4
I am going to take the air cleaners off and check better but can these leak just sitting in the water and not running? I'm still trying to find my leak and plan on taking stuff out to dig around and look for water trailes or marks
JPass
Messages
1,010
Likes
95
Location
Orlando, FL
Water Crafts
#5
They can leak if the bellows have a leak or if the carbon ring is thin, cracked or chunked, but if that was the case it would leak even more under power.
Messages
65
Likes
8
Location
Indiana
Water Crafts
#6
I seen on ebay a guy makes a fork like tool on a pry bar to help with replacing the carbon seal and holding everything back to install or remove the clips would this be something worth buying? I have not done this before but since I work in cars for a living I value a tool made for the job to make it easier and faster.
JPass
Messages
1,010
Likes
95
Location
Orlando, FL
Water Crafts
#7
There are a couple of tools that will make the job easier for sure.
Floating Ring Tool. There are 2 different types depending on engine (155 vs 215/255).
Drive Shaft C-Clip remover
gday
Messages
31
Likes
0
Location
Northern California
Water Crafts
2012 Seadoo speedster 150 HO
#12
Roger on that. However, you might want to checkout seadoo part # 295501143. I believe this is around $89 and includes parts 272000177 AND 272000176. Would reduce your price by ~$110. But please double check. I have one of these kits ready to install on my 2012 Speedster 150 HO.
JPass
Messages
1,010
Likes
95
Location
Orlando, FL
Water Crafts
#13
That kit you reference (below pic) doesn't include new o-rings and bellows. The bellows is what helps to keep tension on the system. Considering this part of the boat is the only thing that keeps water from entering the boat, I'd rather replace everything if I was going to do the job at all. Why risk anything for $100?
Messages
65
Likes
8
Location
Indiana
Water Crafts
#14
So who or were has the best parts and price on these? I see.a lot of options on these and this being new to me I don't want to buy junk. We're can I get the tools you spoke of to make this easier the only thing I've found is the one tool in ebay? Thanks
JPass
Messages
1,010
Likes
95
Location
Orlando, FL
Water Crafts
#15
The above kit is fine as it states they are OEM, but you also need the O-rings and bellows to do the job right. Any local dealer should be able to get the parts. Maybe a site sponsor like PWC Muscle as well.
gday
Messages
31
Likes
0
Location
Northern California
Water Crafts
#16
Pretty sure you missed the point. You listed a carbon ring (272000177) at $89 and the support ring (272000176) at $55. The part # I gave you includes these two parts for a combined total of $89. Doesn't mean you forgo the other parts - just that you are $110 ahead.
-mick
JPass
Messages
1,010
Likes
95
Location
Orlando, FL
Water Crafts
#17
-mick
Got it. I should pay more attention with my early AM posts.
That's a huge savings for OEM from what I got from dealers.
Thanks
Messages
65
Likes
8
Location
Indiana
Water Crafts
#18
I have the 155 so were would I get the tools for it at? I see there are.So many options for the carbon ring kits it's hard to tell what one mine takes.
Messages
65
Likes
8
Location
Indiana
Water Crafts
#19
We're do you order your parts.from? Amazon or? I have a feeling this will be my next project hopefully to fix my leak
Messages
65
Likes
8
Location
Indiana
Water Crafts
#22
Boat just turned 92 hrs and I have no idea if they have been changed. Took it out today and I can't see a leak anywhere and a little water still gets in the boat. But the owners manual say they need serviced at50 so I'm over due maybe
Users who viewed this discussion (Total:2)
Adsense
Latest posts
Usergroup
