Cannot locate1/4" coolant discharge hose location on motor...
Leach Lake
DSCF2505.jpgJust replaced my starter motor and needed to take a few items off of my 2002 GTX-R...All went very well with the exception that I cannot locate the discharge location where the 1/4" hose expells water out to the front left of the seadoo...Have looked and looked but cannot find it!!! I would certainly welcome any help. Photo att. shows the hose that is coming from the FR left eyelet...If you know where this shd att.to please let me know...thanks.
you have a larrger hose that goes from front of cylinder head to tuned pipe, it has a t in it, then the 1/4 hose goes down to the magneto cover heat exchanger, then another comes out of heat exchanger and goes to 90 degree fitting on lower cooling chamber on front of motor -- on bottom -- its a plate, then water runs through it and comes out of rear of motor -- lower plate - here is a pic
Thanks for the quick response...I believe I have these discharge hoses covered..Is there any other discharge hose(s) that are not so easy to see? Big fan of the Tampa area, I go down to Treasure Isl every yerar...Thanks for your help....
