MidnightR6
Hi,
I am new to the forum and I am looking into buying a 1998 Speedster with twin 110 hp engines. The previous owner says "Had a compression test done last year the left engine has lost 2 hp from factory the other checks out perfect no power loss". When I went and looked at the boat, he said that when you take-off, the left rpm guage lags behind a little bit and then eventually matches the right engine rpms shown on the guages.
Do I have anything to worry about? I have read a little on compression checks, but is the fact that the LH motor is indicating that it is starting to lose power a big problem that will eventually lead to having to rebuild the motor?
Thanks so much!
I look forward to being a fellow Sea-Doo owner!
Thanks so much!
